Hi CY Friend,
If I need 6 ASYNC SRAM connect with one chip, how to connect these srams? main chip is nxp 5777c, it has EBI interface.
ASYNC
Fast ASYNC
Our device CY62157H30 (512K Words x 16) has 16 data lines (IO0 to IO15) and 19 address lines (A0 to A18). When connected 6 of this part in depth expansion configuration, from the controller point of view it will be a larger SRAM with size 6 x (512K x 16) = 3072K x 16 and 3 additional address lines will be needed (A0 to A21) to access it.
In depth expansion configuration, data lines (IO0 to IO15), control lines (BYTE#, BLE#, BHE#, OE# and WE#) and the lower address lines (A0 to A18) should be shared between the 6 SRAMs. To select each SRAMs properly, you have to develop a logic to select (CE1# = LOW and CE2 = HIGH) each SRAM using the upper 3 address lines (A19 to A21).
Please see a related KBA here: Width and Depth Expansion of the CY7C1021 (64K x 16) SRAM .
I hope this answers your query. Please let me know, if you need any clarifications.
Thanks and Regards,
Sudheesh
Please provide some more details about your requirement.
1. Which is the Cypress Async SRAM that you use in your application?
2. Are you planning to do width or depth expansion using the 6 Async SRAMs?
3. Please provide some more details about application.
Thanks and Regards,
Sudheesh
Hi Subheesh,
Customer choose CY62157H30-45BVXA, only depth expansion.
Thanks and Regards,
Sudheesh
