What is the maximum power dissipation for CY7C1380KV33-167AXI in a continuous 85 deg C ambient
Memory SRAM
Hi @tsog35h ,
Kindly refer to the below App note for calculating the maximum power dissipation. Also, you may refer to the example (section-4) in the App note for the calculation.
AN4017- Understanding Temperature Specifications: An Introduction (https://www.cypress.com/file/38656/download)
You may also take the help of our tool to calculate the power dissipation. I have attached the tool with this response.
Ritwick
Hi @tsog35h ,
Ritwick
