Mar 28, 2021
10:39 PM
I want to use QDRIV: CY7C4142KC13 as a memory for my Xilinx versal AI device.
The FAE of Xilinx said their hardware IP doesn't support QVLDA0,1&QVLDB0,1.
So could you tell me how should I connect QVLDA0,1&QVLDB0,1 rightly when these pins are not used?
Thanks very much.
Labels
Memory SRAM
04:10 AM
The QVLD pins are output pins. You can leave them floating if you are not using them.
Pradipta.
04:10 AM
Pradipta.
Mar 29, 2021
06:59 PM
Hi, Pradipta
Thanks for the answer.
