Can I continuously write to this ASRAM by pulling Write Enable and Chip Enable pins
low all the time and changing address after each Write Cycle Time, or I need to pull Write Enable pin high after each writing.
And when the data is latched to the input buffer ?
thanks.
You need to pull the Write enable high. Keeping WE and CE low all the time an changing address may not work.
krishna.
krishna.
Sampling of data is done is with respect to either CE or WE line .
Krishna.
