I could not find the VDDQ supply power consumption in datasheet. Could you provide a maximum current consumption of VDDQ of part CY7C2663KV18-450BZI ?
Also you could provide that if Vref (0.75V) draw current or not ?
Hi Doner,
Please refer to the Application note below. It has an "online tool for calculating the Junction temperature" on page 5 of the app note. You can use the online calculator to calculate the supply power consumption. It also has example for QDR II+ devices so you can refer to that and calculate the values as per your case.
http://www.cypress.com/file/38656/download
Vref pin will consume current. The value will depend on the loading that is observed by the Vref pin.
Hi Doner,
