camino
Distributor - TED (Japan)
5 solutions authored 10 replies posted First solution authored
We will use CY62137FV18 as 1-Mbit and need to know how A16 pin should handle.
 Does A16 pin pin have pull-up or pull-down resister internally ?
 Otherwise should external pull-up or pull-down resistors be provided for A16 pin ?
YukaA_81
5 solutions authored 10 replies posted First like given
HI,
If you use CY62137FV18 (2Mb product) as 1Mb product, AD16 must be pulled up or pulled down, or controlled in the same way as other AD pins on the host side.
IFX) Y.Ami
YukaA_81
HI,
IFX) Y.Ami
