SRAM Forum Discussions
We have a product using a 70ns SRAM low power version and recently has swithed to a 45nS second source(lower power consumtion then the orginal one). and the product started to have some strange failure, had spend some time checking on various parts and found the replacing the SRAM with the slower one fix the problem. We are using a 8051 type controller. What would be the problem, we looked at the bus signal and all seems to be clean.
Bob_Marlowe
Level 10
Level 10
What is about the setup & hold times of the address latch? Any ringing on the adr / data lines??
Bob
 Tks bob,
The signals are clean, no obvious ringing found. We didn't check the setup /hold time, shall check it tomorrow. But how would a faster chip had this timming issues?
The problem seems to be the setup time of the address line WRT the write strobe.
