SRAM Forum Discussions
     The QDRII SRAM has three pairs of clock signals.
     Ø            K, K#: input clocks
     Ø            C, C#: output clocks
           (Note: C and C# clocks are not offered for QDRII+ devices)
     Ø            CQ, CQ#: echo clocks: source-synchronous  output clocks from the SRAM that accompany read data
           The CQ and CQ# clocks are edge-aligned with read data. For high-frequency applications (>=250MHz), CQ and CQ# clocks are preferred for data capture.
     The CQ and CQ# clocks and the data output have the same source. The echo clock is source synchronous and edge aligned with the data. So echo clock tracks data better than the K clock.
     CQ and CQ# clocks also tracks the data switching noise better than the K clock. This results in better data valid window for the data outputs using CQ/CQ# clocks compared to K clocks.
