SRAM Forum Discussions
sktam
Does cypress have a memory controller IP for Xilinx's Zynq Ultrascale+ devices?
PradiptaB_11
You can refer to the Xilinx documentation for your requirement.
https://www.xilinx.com/support/documentation/ip_documentation/ultrascale_memory_ip/v1_2/pg150-ultras...
Pradipta.
PradiptaB_11
Pradipta.
Hello Pradipta,
I'm spoke with Xilinx  about their QDR-IV memory controller for their Zynq Ultrascale devices but they could not confirm support for the depth expansion per section 9 of Cypress's QDR-IV Design Guide AN84060.  They referred me to Cypress to see if your team has provided an QDR-IV controller that supports depth expansion.  Can I infer from your response that Cypress does not have a QDR-IV memory controller for Zynq Ultrascale+ devices?  Do you know if Xilinx's memory controller will support depth expansion?
Thanks for your help,
Steve
PradiptaB_11
Hi Steve,
We have one controller for internal use but it was developed to use one memory at a time. For depth expansion you will require multiple lbk signals. I could not find this in the Xilinx IP or in the document. You may have to create/write some soft IP to do this.
Pradipta.
