nrks_4454101
Dear Cypress,
We have used industrial grade QDR-II+ part # CY7C2663KV18-450BZI in proto design. This part has to be replaced with high temperature (minimum 105°C) equivalent part for the production version which has to be qualified for high temperature profile test.  Could you please suggest   Automotive grade or High ambient temperature (105°C / 125°C)  equivalent for # CY7C2663KV18-450BZI.
Nrupathunga
PradiptaB_11
Hi Nrupathunga,
You can check the below parts for the application. I also suggest you to contact your nearest  Cypress FAE or our Marketing Team for more assistance on this issue.
https://www.cypress.com/part/cyrs2643kv18-250gcmb
https://www.cypress.com/part/cypt2643kv18-250gcmb
Pradipta.
PradiptaB_11
Hi Nrupathunga,
Pradipta.
