SRAM Forum Discussions
 Can I use your QDR II/II+ products as QDR I?
PriteshM_61
25 solutions authored 10 solutions authored 5 solutions authored
Hi Electron,
Yes, you can use our QDRII/II+ products as QDR I.
You can turn off the PLL inside the device by connecting the DOFF/ pin to ground and the device behaves in QDR-I mode
when the PLL is turned off.
For more information, you can refer the following application note (AN46982),
http://www.cypress.com/?rID=53503
PRIT
PriteshM_61
Hi Electron,
PRIT
