Jmar_12
In a question I posted on 4/21/2021 (Thermal resistance values for CY7C) it was stated " As per our packaging team we have simulated Theta JB which is 13.45 C/W using an 8-Layer (101.5 x 114.4 x 1.6mm) PCB."
However, this value is greater than the  data sheet Theta JA (12.23 °C/W) which does not make too much sense. For a typical FBGA package without an exposed heat sink or heat spreader, majority of the heat is removed from the base of the package.
Can you provide some insite on this?
PradiptaB_11
I think there was a typo from our side in the previous post. Please refer to the below values that we have with us both from simulation and measurements. A device soldered on the PCB should observe a lower Theta JB value. We believe the PCB in the data below plays a bigger role in the lower value than the socket.
Type
Simulation
Measurement
Board Mount
Soldered
Socketed
test Condition
102x114x1.6mm, 8-layer PCB
170x220×2.35mm, 8-layer PCB
Theta JA
16.11⁰C/W
12.23⁰C/W
Theta JB
11.72⁰C/W
9.34⁰C/W
Theta JC
2.1⁰C/W
2.1⁰C/W
Pradipta.
PradiptaB_11
We will need to check this with our team internally. Will keep you updated on this.
Pradipta.
PradiptaB_11
Type
Simulation
Measurement
Board Mount
Soldered
Socketed
test Condition
Theta JA
16.11⁰C/W
12.23⁰C/W
Theta JB
11.72⁰C/W
9.34⁰C/W
Theta JC
2.1⁰C/W
2.1⁰C/W
Pradipta.
Pradipta,
Thanks for the response. You stated "A device soldered on the PCB should observe a lower Theta JB value. We believe the PCB in the data below plays a bigger role in the lower value than the socket." I agree with your statement, but the soldered value you have listed (11.72C/W) is higher than the socket value (9.34C/W) which contradicts what you said above. Can you clarify?
PradiptaB_11
Hi
Yes, even though both PCBs are 8 layer, the socketed PCB is much larger and thicker, which is why we believe the Theta JB value is lower on the socketed PCB. So, we should not consider this  as a contradiction.
Pradipta.
