i'm a new user, i need your help for a question.
Working with CMOD A7 35T board i have found a problem, the SRAM isn't enough, so i have proposed to add an external SRAM..
We need at least 4MByte SRAM, at first time we want test it using breadboard and later weld it on my board.
Can someone suggest me which is the best SRAM chip for my purposes? And it's easy to comunicate with it using Vivado Xilinx tool?
Thanks you
Regards Stefano
ASYNC
Stefano,
Below is the URL which has list of our 32Mbit ( 4MByte) devices. Depending on the package,voltage and configuration you can choose a device of your choice.
Stefano,
