On-die termination (ODT) in QDRII+ SRAMs doe not impact core power. Hence the Idd current specified in the datasheet for ODT and non-ODT parts will be the same.
This is because the ODT circuit within the device is powered by Vddq(I/O voltage supply) and not Vdd (core voltage supply).
For more details refer to application note AN42468 in the link below:
Hi
i want to know the purpose of the ODT . I have the doc of the ODT, i have a doubt that it effect the calibration of the memory .
I need a help, i am in confuse
Hi Subashbabu,
We have received the similar query from you on the following forum post. Please refer the same for my response.
http://www.cypress.com/?app=forum&id=64&rID=52728
Also, I came to know that you have opened a technical support case with us. Please let us know if you would like to have a call on this issue.
