CY7C4285V-15ASI PIN 55 GND pin is not connect with the wafer
AiZh_4671661
part number CY7C4285V-15ASI, the pin 55 for this part is GND part, but it is open, it is not connect with the wafer. would this be an problem to use the part ? will this cause the reliability problem?
