CY7C2663KV18-450BZI component height tolerance from PCB is required for thermal analysis. I need to know that min, typical and max height value in mm. Below drawing is given in the datasheet. Max value is given, But I could not get min and typical values from PCB to IC top by using below drawing.
Thank you,
- sram
Hi Doner,
Please find the below details for the 165 FBGA(15 x 17 mm) package.
Nom.-------1.24
Min.---------1.13
Max.---------1.4
The 0.15 is the dimension for the package coplanarity which is 0.15mm.
Thanks and Regards,
Pradipta.
Hi Doner,
Nom.-------1.24
Min.---------1.13
Max.---------1.4
Thanks and Regards,
Pradipta.
