Hi all,
I'm developping CY7C1474V25-209FBGA footprint but I can't find, in the datasheet, the excat position of every address pin (only A0 and A1 are specified but not the others).
Could you help me?
Thanks in advance.
Lorenzo Massari
Hi Lorenzo,
Once a address pin is assigned with a particular address bit, You will Read and Write from the same address. So, it doesn't affect the Read and Write operation. Hence, we do not provide the exact Address(A) pin numbers . Please refer the following knowledge base article for further explanation.
http://www.cypress.com/?id=4&rID=26487
Prit
Thanks for your reply.
Is there the possibility to know the exact physical position of the address?
It should be very useful for the kind of test we would like to perform.
Regards.
Lorenzo Massari
