HI,
I am using CY7C1041G30-10ZSXI SRAM which is interfaced with microsemi samrt fusion 2 FPGA. In interfacing the part to FPGA, I am not sure any kind of termination (like series resistor, as of now no terminations are considered as it cmos output and inputs) is required here to reduce the reflection between the device other than length matching (+/-10mils in FR4 board) and impedance (50+/-10%) control in PCB. Maximum operating frequency considered as 100MHz
Kindly recommend any terminations are to be considered for this particular interface and let me know if any other considerations to be taken for reducing the reflection.
If you have matched the load impedance to the line's characteristic impedance it will suffice. Also i am attaching SRAM board design guidelines along with it.
https://www.cypress.com/file/38651/download
Pradipta.
