CY7C1021DV33-10ZSXI - Write cycle query
user_2283911
We are using 1Mb ASYNC SRAM  CY7C1021DV33-10ZSXI in our new design.
The datasheet of this device mentioned 3 modes of write cycle on page - 9 and 10. These modes are -
1) Write Cycle No. 1 (CE Controlled)
2) Write Cycle No. 2 (BLE or BHE Controlled)
3) Write Cycle No. 3 (WE Controlled, OE LOW)
The datasheet of  2Mb part CY7C1011DV33 of this series has mentioned one extra mode i.e. - Write Cycle No. 3 (WE Controlled, OE HIGH During Write)
We want to use this "Write Cycle No. 3 (WE Controlled, OE HIGH During Write)" mode for writing the data in SRAM as there will be a continuous write in our application. so, we want to make OE# high for entire write duration.
so, please confirm that, is this  "WE Controlled, OE HIGH During Write" write cycle mode also applicable for 1Mb SRAM part - CY7C1021DV33-10ZSXI
for ref, i am attaching the WE Controlled, OE HIGH During Write" write cycle mode snapshot mentioned in 2Mb part.
Thanks and Regards
Tarang JIndal
PradiptaB_11
Hi Tarang,
Yes, you can use WE# low and OE# high for write cycle in 1Mb part also, infact in all density parts.
The purpose of providing an OE# low and WE# Low waveform for write cycle was to highlight the fact that even if the user disables the output (by driving OE# high) the write is still going to happen in the memory. It only signifies that WE# pin needs to be low for a write to happen irrespective of the status of OE#. You can check this in the truth table also provided in the datasheet.
Thanks and Regards,
Pradipta.
PradiptaB_11
Hi Tarang,
Thanks and Regards,
Pradipta.
