I have the following questions about SRAM PN CY7C1019DV33-10VXI for use in aerospace application. This SRAM is a potential option for our design to address an obsolescence issue.
1. The datasheet indicates that the chip can be powered at -55 degC. Is there any data available on the performance variability between -55 degC & -40 degC ?
2. What is the failure behavior at -55degC ? Will it stop operating or will there be variability in performance of the various read/write parameters ?
3. Is it possible to share the PN of the die used in this SRAM ?
4. Is there field data/reliability data available for this SRAM ?
5. Is there any information on NSEU susceptibility rates ?
6. Can Cypress support up-screening of these SRAMs to meet military temperature rating of -55 degC to +125 degC
Memory SRAM
All your queries requires some confidential data which we cannot share on public forum due to legal issues. I will suggest you to kindly create a support case with us for the queries where they can be answered.
Pradipta.
Pradipta.
