Does anyone here have the .bsdl file for this device? I'm trying to "JTag" this device.
Jtag is not working for me. What am I missing here...
ASYNC
Hi Brandon,
Can you try using the below file.
https://www.cypress.com/documentation/models/cy7c0853v-133bbc-bsdl
Pinout is same for both Commercial and industrial part so it will not be an issue.
Pradipta.
Thanks for confirming the file. I used that but I still not able to jtag it.
Not able to get into Jtag mode or something...
*/Brandon Xiong
Global Electronic Test Services, USA
Phone: (727) 807-7991 x103
Fax: (727) 807-7992
Email: brandon@gets-usa.com <mailto:brandon@gets-usa.com>
Web: www.gets-usa.com <http://gets-usa.com> /*
Brandon,
Can you share the error you are getting?
What is the setup to get into Jtag mode?
This part and model has been stable for several years now.
Nilesh
Hi Nilesh,
1. can you confirm if the .bsdl file is for this device?; this is the
only file I've found
2. I've noticed not all "Vdd"'s are not connected to each other? ;is
this normal
3. I've noticed not all "Vss" are not connected to each other? ; is this
normal
What is required to get into "jtag mode"?; I'm still missing something
here...
My test results tells me im not in Jtag mode.
We believe this part is authentic due to the die marking matches...
Let me know, thanks!
*/Brandon Xiong
Fax: (727) 807-7992
