SRAM Forum Discussions
DnSa_3928236
CY14B256LA-ZS25XI I am using NVRAM. I am unable to read/write data in NVRAM.
As I have checked all the signal status as per datasheet still not working.
Kindly suggest the solution...
Dnyaneshwar
Mumbai, India
PradiptaB_11
Hi
Can you provide the complete procedure as to how you are observing this issue.
Did you check the signals at the memory side or the controller side when you verified them
How many chips are showing this behavior. Are all IC showing this behavior or some of them.
Thanks and regards,
Pradipta.
