SRAM Forum Discussions
MAO
Level 4
Level 4
25 replies posted 50 questions asked First solution authored
The customer wanted to use the IBIS model for SI analysis, so I was irritated to ask for materials.
Isn't it wrong with the following file?
Also, I get the following error, can you figure out the cause?
ritwicksharma
250 sign-ins 100 replies posted 50 solutions authored
Hi @MAO,
Unfortunately, we don't have the IBIS model for CY62158ELL. The closest to it which we have is model for CY62156ESL. Please find the model attached.
Ritwick
ritwicksharma
Hi @MAO,
You are using the wrong file for IBIS simulation. There is a different file for it that is not currently there on our website, and regarding that, I will check internally and get back to you. Also, could you please translate the error into English?
Ritwick
The above is the English content of the error
Thank you
ritwicksharma
Hi @MAO,
I was asking about the below error to translate into English.
Ritwick
Here you will
Thank you
ritwicksharma
Hi @MAO,
Ritwick
