About SRAM, CY621472G30-45ZSXI
MAO
Distributor - Macnica (Japan)
5 solutions authored 50 replies posted 100 sign-ins
Assert CS(chip enable) and OE (output enable) pins
Is it possible to continuously read the data signal by switching the address signal? (Page Lead)
PradiptaB_11
Hi @MAO ,
Yes, the above procedure is applicable and is one of the 3 procedures to read the device. You can refer to the datasheet figure 10 and 11 for all the timing specifications for this read cycle.
https://www.infineon.com/dgdl/Infineon-CY62147G_CY621472G_CY62147GE_MoBL_4-Mbit_(256K_words_16_bit)_...
Pradipta.
PradiptaB_11
Hi @MAO ,
Pradipta.
