WICED Smart SDK 2.x Smart Designer Tool Overview
RevisionChange DecriptionDate
1.0Initial Video - No Audio - 6 minutes06/23/14
1.1Added Audio06/24/14
1.2
Added detailed Smart Designer video - Uses Microbrewery and Beer Drone as Services and Characteristics explanation
09/22/14
Hello Community Members,
Welcome to the WICED Smart Video BLOG Series
This Video BLOG should be used as a "guide" for walking through the Smart Designer Tool in SDK 2.1.
This video will illustrate a great feature to use for configuring the GATT for Bluetooth SIG approved profiles + Vendor Specific Profiles.
This Smart Designer Walk-Thru uses a Sensor Device with the following sensors needed to be configured with Vendor Specific Characteristics:
  1. Temperature
  2. Barometric Pressure
  3. Humidity
  4. Gyro
  5. Magnetometer - eCompass
We have made it fun by showing a Microbrewery Sensor Configuration and a Beer Drone example - Hope you enjoy it!
It is a big file and 30 minutes, so view it when you have some time.
New Video starts here:
                                          Video Link : 1119
JT
Comments
Great introduction!
I have installed Wiced SDK 2.0.1 and have attempted to follow the video.  I can select the Smart Configuration Tool and it asks me to name the project.  After I name the project, the window disappears and all I see is the IDE.  Any idea what I'm doing wrong?  Do I have to have a 20737 connected to develop using the Smart Configuration Tool?
Any help would be appreciated!
Michelle
Hello shellpry,
Please download the SDK 2.1.1 here: WICED-Smart-SDK-2.1.1-IDE-Installer (Windows)
You don't need to have the 20737 device connected to use Smart Designer.
Let me know how that works for you.
JT
That took care of it!!!!  Thank you very much.
Michelle
Fantastic!
JT
HeLo_1712431
In our application, some characteristic needs data size of 512 bytes.  Could you let me know when this Designer will support this?  It looks like the designer is supporting data length only up to 253 bytes in the database.
MichaelF_56
Moderator 250 sign-ins 25 comments on blog 10 comments on blog
Could you post this as a question in the main forum here: WICED Smart Forums
I'm not sure the AE team is monitoring questions posted as comments against blogs.
Contributors
