Using AP(softAP) and STA(client) simultaneously
GregG_16
50 sign-ins 25 sign-ins 25 comments on KBA
Several people have asked about using the WICED module as a SoftAP (AP) and a Client (STA) at the same time.
In this Blog, we will demonstrate this with the Console test App.
First, compile, download and run the Console Test App:
This can be done with the following "Make Target" test.console-BCM943362WCD4 download run
Next assure via the Serial port console window that the Console app is running
For more information on this Serial Port Communication to WICED Module
Typing 'help'  will scroll a long list of commands.
> help
Console Commands:
     help [<command> [<example_num>]]
         - Print help message or command example.
     loop <times> [ <semicolon_separated_commands_list> ]
         - Loops the commands inside [ ] for specified number of times
     antenna <0|1|3>
         - Antenna selection. 3 = Auto
     get_noise
         - Get PHY noise after successful TX
     get_ap_info
         - Get AP information
     get_access_category_parameters_sta
         - Get access category parameters for STA
     get_associated_sta_list
         - Get list of associated clients
     get_counters
         - Get counters
     get_country
         - Get country.
     get_rate
         - Get current rate.
     get_data_rate
         - Get data rate.
     get_mac_addr
         - Get the device MAC address.
     get_pmk <key>
         - Get PMK
     get_random
         - Get a random number.
     get_rssi
         - Get the received signal strength of the AP (client mode only).
     get_soft_ap_credentials
         - Get SoftAP credentials
     get_tx_power
         - Gets the tx power in dBm.
     join <ssid> <open|wep|wpa_aes|wpa_tkip|wpa2|wpa2_tkip> [key] [ip netmask gateway]
         - Join an AP. DHCP assumed if no IP address provided
     join_specific <ssid> <bssid> <channel> <open|wep|wpa_aes|wpa_tkip|wpa2|wpa2_tkip> [key] [ip netmask gateway]
         - Join specified AP. DHCP assumed if no IP address provided
     leave
         - Leave an AP.
     scan
         - Scan all enabled channels and print a list of APs found.
     set_legacy_rate <1|2|5.5|6|9|11|12|18|24|36|48|54>
         - Set legacy (CCK/OFDM) rate on PHY
     set_mcs_rate <MCS Index> <Override MCS only>
         - Set MCS rate on PHY
     disable_11n
         - Disable 11n mode operation
     enable_11n
         - Enable 11n mode operation
     set_data_rate <1|2|5.5|6|9|11|12|18|24|36|48|54>
         - Set data rate.
     set_ip <ip> <netmask> <gateway>
         - Set a static IP.
     set_listen_interval <listen interval> <time unit>
         - Set listen interval in time unit 0 = Beacon Intervals. 1 = DTIM Intervals
     wifi_powersave <mode> [delay]
         - Enable/disable Wi-Fi powersave mode. 0 = disable. 1 = PS Poll. 2 = Wait [delay] ms before entering powersave
     set_tx_power <0-31>
         - Set the tx power in dBm.
     start_ap <ssid> <open|wpa2|wpa2_aes> <key> <channel> <wps>
         - Start AP mode.
     status
         - Print status of the Wi-Fi and network interfaces.
     stop_ap
         - Stop AP mode.
     test_ap <ssid> <open|wpa2|wpa2_aes> <key> <channel> <wps> <iterations>
         - Test AP mode.
     test_join <ssid> <open|wep|wpa_aes|wpa_tkip|wpa2|wpa2_tkip> [key] [ip netmask gateway] <iterations>
         - Test joining an AP. DHCP assumed if no IP address provided
     test_join_specific <ssid> <bssid> <channel> <open|wep|wpa_aes|wpa_tkip|wpa2|wpa2_tkip> [key] [ip netmask gateway] <iterations>
     test_cred <ssid> <bssid> <channel> <open|wep|wpa_aes|wpa_tkip|wpa2|wpa2_tkip> [key]
     ping <destination> [-i <interval in ms>] [-n <number>] [-l <length>]
         - Pings the specified IP or Host.
     force_alignment
         - Force aligned memory accesses
     join_wps <pbc|pin> [pin] [<ip> <netmask> <gateway>]
         - Join an AP using WPS
     join_wps_specific [pin] [<ip> <netmask> <gateway>]
         - Join a specific WLAN using WPS PIN mode
     scan_wps
         - Scan for APs supporting WPS
     start_registrar <pbc|pin> [pin]
         - Start the WPS Registrar
     stop_registrar
         - Stop the WPS Registrar
     p2p_connect <pin|pbc> [8 digit PIN]
         - Connect to an existing Group Owner or negotiate to form a group
     p2p_client_test <SSID> <8 digit PIN> [Iterations]
         - Test P2P client connection to existing group owner
     p2p_discovery_disable
         - Disable P2P discovery mode
     p2p_discovery_enable
         - Enable P2P discovery mode
     p2p_discovery_test [iterations]
         - Test enable/disable of P2P discovery mode
     p2p_go_start <p|n> [<ssid_suffix> <key> <operating channel>]
         - Start P2P (p)ersistent or (n)on-persistent group
     p2p_go_stop
         - Stop P2P group owner
     p2p_go_test <p|n> [iterations]
         - Test start/stop of (p)ersistent or (n)on-persistent group
     p2p_go_client_test_mode <enable=1|disable=0> <pin value>
         - Allow test client to join using PIN value
     p2p_leave
         - Disassociate from P2P group owner
     p2p_negotiation_test <8 digit PIN> [Iterations]
         - Test P2P negotiation handshake
     p2p_peer_list
         - Print P2P peer list
     p2p_registrar_start <pin|pbc> [8 digit PIN]
         - Start P2P group owner's WPS registrar
     p2p_registrar_stop
         - Stop P2P group owner's WPS registrar
     p2p_set_go_intent <intent value>
          - Set P2P group owner intent (0..15 where 15 = must be GO)
     p2p_set_go_pbc_mode_support <0|1>
          - Set P2P group owner support for PBC mode (1 = allow, 0 = disallow)
     p2p_set_listen_channel <channel>
         - Set listen channel (1, 6 or 11)
     p2p_set_operating_channel <channel>
         - Set operating channel (1..11)
     iperf
         - Run iperf --help for usage.
     iperf_test
         - iperf_test [iterations] iperf command
     malloc_info
         - Print memory allocation information
     thread_list
         - [ThreadX only] Lists the current running threads
     thread_kill <thread id>
         - [ThreadX only] Kills the specified running thread
     thread_spawn [priority] <cmds>
         - [ThreadX only] Spawns a new thread for the specified command. Optionally run at a specific priority.
     reboot
         - Reboot the device
     mcu_powersave <0|1>
         - Enable/disable MCU powersave
     traffic_stream_ipv4 [-c <destination ip>] [-p <port>] [-u (for udp)] [-l <length>] [-d <duration in seconds>] [-r <rate (pps)>] [-S <type of service>] [-i <interface>]
         - Start a traffic stream.
In this demo we will use the following commands:
status
scan
     - Start AP mode.
stop_ap
     - Stop AP mode.
leave
- Leave an AP.
First let's check the "status"
> status
WICED Version  : 3.1.2
Platform              : BCM943362WCD4
MAC Address     : 44:39:C4:31:14:83
STA Interface     : Down
AP Interface       : Down
P2P Interface     : Down
You can see from the output that the STA and AP interfaces are both down.
Next we can join an existing network:
Type 'scan' to see who is available:
> scan
Waiting for scan results...
  # Type  BSSID                      RSSI  Rate Chan Security    SSID
  0 Infra 00:16:01:A1:98:38     -68    144.4     1    Open              Nidal-Out
  1 Infra 00:90:4C:10:E2:20    -57     216.7    1    Open              BSD-Android-Test
  2 Infra B8:BE:BF:15:AF:B2  -38     144.4    1    WPA2 AES    BRCMWiFi
  3 Infra B8:BE:BF:15:AF:B1  -38     144.4    1    WPA2 AES    brcmwpa
  4 Infra 04:A1:51:38:63:AD    -65     216.7   1    WPA2 AES    NETGEAR24-BT
  5 Infra B8:BE:BF:15:AF:B0   -36     54.0     1    WPA2 AES    BRCMGUEST
End of scan results
Next we will join an AP, in this example "BRCMGUEST"
> join BRCMGUEST wpa2 <passphrase>
Joining : BRCMGUEST
Successfully joined : BRCMGUEST
Obtaining IPv4 address via DHCP
Setting IPv6 link-local address
IPv4 network ready IP: 10.16.101.9
Now check the status:
> status
STA Interface
   SSID               : BRCMGUEST
   IP Addr           : 10.16.101.9
   Gateway         : 10.16.96.1
   Netmask         : 255.255.248.0
AP Interface      : Down
You can see we have successfully joined the network and received an IP address via the DHCP server.
Next we start an AP:
If you type start_ap you will see the correct syntax:
> start_ap
Usage: start_ap <ssid> <open|wpa2|wpa2_aes> <key> <channel> <wps>
Let's start an AP with the SSID 'gangi' with WPA2 security and a passphrase of '12345678' on Channel 1
PLEASE NOTE: The AP and STATION need to be on the same channel!  In this case it is 2.4GHz Channel 1.
> start_ap gangi wpa2 12345678 1
IPv4 network ready IP: 192.168.0.1
Look at the Status again:
> status
STA Interface
   SSID                : BRCMGUEST
AP Interface
   SSID                : gangi
   IP Addr            : 192.168.0.1
   Gateway          : 192.168.0.1
   Netmask          : 255.255.255.0
Now you can see we have a AP interface and a STA Interface simultaneously running.
You can easily stop the soft AP using 'stop_ap' and leave the AP using the 'leave' command
> stop_ap
> status
STA Interface
   SSID                : BRCMGUEST
AP Interface      : Down
> leave
> status
AP Interface       : Down
Enjoy. Hope this helps!
Please direct questions and comments to:
seyhan and gangi
Comments
very useful, thanks! !!!
