The 'IDAC Gain' parameter miss synchronization between Customizer and Tuner in CapSense_v7_0
Vison_Zhang
First comment on KBA 750 replies posted 250 sign-ins
Question
In CapSense_v7_0, why the  'IDAC Gain' parameter of widget shows in Tuner is different with Customizer setting.
Answer
In CapSense_v7_0 customizer, when 1200nA/bit, 2400nA/bit or 4800nA/bit option is selected as the widget 'IDAC Gain', in Tuner it will be mis-displayed as 2400nA/bit, 4800nA/bit and N/A respectively. This is a known defect of CapSense Tuner tool, which cause the 'IDAC Gain' parameter miss synchronization between Customizer and Tuner.
 The problem exists only with the CapSense Tuner tool. But the IDAC gain selection is correctly handled by the CapSense Customizer tool. User is still able to setup any gain by using the CapSense Customizer tool.
 DAC Gain synchronization relationship between Customizer and Tuner
Widget
Customizer
Tuner
Btn 0
37.5
37.5
Btn 1
75
75
Btn 2
300
300
Btn 3
600
600
Btn 4
1200
2400
Btn 5
2400
4800
Btn 6
4800
N/A
