- Mark as Read
- Email to a Friend
- Printer Friendly Page
TAG3 Serial Flash Configuration
This BLOG is a short introduction for configuring the TAG3 board for use with the Serial FLASH.
This information is taken from our TAG3 document Manual : The specified document was not found. and our Quick Start Guide The specified document was not found.
1. The TAG3 board contains a Serial FLASH device and can be configured with a few resistor modifications and additions:
See the TAG3 Board below:
2. TAG3 Board Assembly displaying the resistor installation/modifications for the on board Serial FLASH:
3. The table below defines the resistors to configure the Serial FLASH:
4. You will need to place the SW4 switches 5,6,7,8 in the OFF position (They are actually show in the ON Position in this photo):
5. In the SDK you will need to modify your Make Target to include NV=SFLASH:
Note: In this case we have used COM Port 21 as observed in our Windows Device Manager:
5. Using the Recovery Procedure from the The specified document was not found. document, your recovering console message should look like the following:
A few extra notes about Serial FLASH:
You will need to use the same Macronix Serial Flash that is supported by the ROM and ships on the TAG3 board. Please see the schematic snippet below:
The Macronix MX25U4033 device works as well if you needed a second option.
Please see the notes below:
MX25U4033: https://www.macronix.com/en-us/products/NOR-Flash/Serial-NOR-Flash/Pages/spec.aspx?p=MX25U4033E&m=Se... (good for new designs)
MX25U4035: https://www.macronix.com/en-us/products/NOR-Flash/Serial-NOR-Flash/Pages/spec.aspx?p=MX25U4035&m=Ser... (not recommended for new designs)
Regarding the two different Flash PNs, here’s a document from the Macronix website that compares the two:
https://www.macronix.com/Lists/ApplicationNote/Attachments/1872/AN126V1_MX25U4035%20to%204033E.pdf
- Mark Article as New
- Mark Article as Read
- Email to a Friend
Very nice! Thank you sir JT.
- Email to a Friend
What's the value for the R100 and R101"install" ?
- Email to a Friend
Per the schematic in the back of the Hardware User Guide (SDK 2.x and TAG3 Board), I believe these are 0 Ohm DNI resistors.
- Email to a Friend
For EEPROM, R100 and R101 are DNI, 0 Ohm. But for the Serial Flash, they are "Install", I need to know the "Install" value, the resistor size... Thank you!
- Email to a Friend
- Email to a Friend
Hi mwf_mmfae,
Thank you very much!
Ellen
- Email to a Friend
Hello Ellen,
The "Install" value is a 0 Ohm resistor.
JT
- Email to a Friend
Hi JT,
Do you have BCM20737A1KML2G datasheet? I could not find it in the Broadcom website.
Ellen
- Email to a Friend
Here you go: BCM20737 SOC Data Sheet
- Email to a Friend
Thank you so much mwf_mmfae !
