- Mark as Read
- Printer Friendly Page
SPI example for CYW20706
This application demonstrates how to use SPI driver interface on CYW20706 to send and receive bytes or a stream of bytes over the SPI.
Hardware connections on CYW20706 EVAL:
For SPI Slave use the below pins :
- CS - P26
- MOSI - P27
- MISO - P25
- CLK - P36
For SPI Master use the below pins :
- CS - P26
- MOSI - P0
- MISO - P25
- CLK - P36
Test Procedure:
- Program 1 kit with the spi_master app and another kit with spi_slave app (attached the project).
- Connect the SPI lines and ground on the 2 kits.
- Power on the kits. You can see the logs through PUART
- Reset the SPI master first and then SPI slave.
- Mark Article as New
- Mark Article as Read
有几个问题请教一下:
1.您使用的WICED是什么版本?我有很多API与您的不相同
2.您SPI Master Demo中#define MASTER1_P36_CLK_P00_MOSI_P25_MISO 0x00240019
“0x00240019 ”是如何得到的?
3..您SPI Master Demo中使用的GPIO为P36\P00\P25\P26吗??与您Blog中介绍的不符??请问实际使用的GPIO为哪个?
1. I am using WICED SDK 6.2
2. available pin combinations are in spiffydriver.h
The value can be find out as below
MASTER - 0x[00][hex of clock pin (eg: 24(hex of 36) for P36 )][hex of mosi pin][hex of miso pin]
SLAVE1_P36_CS_P24_CLK_P27_MOSI_P25_MISO 0x[hex of CS pin number][hex of clock pin ][hex of mosi pin][hex of miso pin]
3. Couldn't able to understand your query.
Anjana
Hi Anjana,
I am using WICED SDK 6.2,copy your code and config pins follow you。
But logs through PUART always are [Rx]Sent start byte。
Follow code,it can't pass if(ACK_ID == rec_byte[0]),do you have some suggestion to check it?
Leo
Can you please try by P33 switch position in OFF on PUART SELECT SW5 ?
Please try reset both devices (first master and then slave) and try.
3.The Hal_spi_master.c is #define MASTER1_P36_CLK_P00_MOSI_P25_MISO 0x00240019.but Your introduction
- CS - P26
- MOSI - P27
- MISO - P25
- CLK - P36
Sorry , it was a mistake from my side. Modified the intro.
Sorry for the inconvenience.
Anjana
Thank you for your support.
HI,
Am a new to cypress micro controller, and working with ADXL345 accelerometer sensor need to integrate with MCU that is CY8C4147AZI-445S. Can anyone please help me interface?
