Plant Moisture Control With Bluetooth Mesh
- Mark as Read
- Printer Friendly Page
This project was submitted by @Akhil Srinivas in The Cypress Bluetooth 5 IoT Design Contest with Mouser and Electromaker.io and was one of the winners!
Project Technology Focuses
- CYW20819 Dual-Mode Bluetooth 5 MCU
- Bluetooth Mesh
- Cypress BT Mesh Android Mobile App
- Capacitive Moisture Sensing
Project Requirements
Hardware
- EZ-BT™ Bluetooth Mesh Development Kit (CYBT-213043-MESH)
- Capacitive Soil Moisture Sensor (SEN0193)
Software
Project Description
This project implemented a very interesting mesh application that is sure to be product-ized in the near future, if not already. A plant Water Density Mapping System was created with the EZ-BT Bluetooth Mesh Development Kit. Capacitive Soil Moisture Sensors were attached to each Mesh Node and an enclosure around the Mesh Node was created to protect the PCB. These moisture-sensing mesh nodes were then placed in a plant pot. Through a mesh network, the moisture sensor data was collected at a proxy node (also one of the moisture sensing nodes) and streamed to a customized version of the Cypress Android Mesh Reference Mobile App.
Project Links
- Project Code
- Full Project Tutorial on Electromaker.io
Resource List
- Bluetooth SDK Documentation
- Bluetooth SDK Technical Brief
- Bluetooth SDK Example Projects
- Cypress Bluetooth Mesh Webpage
- Cypress Bluetooth SDK Community Forum
- CYW20819 Dual-Mode Bluetooth 5 MCU Datasheet
- CYW20819 Feature and Peripheral Guide
- CYW20819 Low-Power Guidelines
- Getting Started With Bluetooth Mesh App Note
