- Mark as Read
- Printer Friendly Page
List of Kernel patches - FMAC
This blog post shows GIT command usage to get the list of commit logs.
Refer this link to find the list of patches submitted in kernel.org.
List of FMAC changes
The following GIT command shall be used to filter FMAC related commits writing to a separate log file.
> git log --graph --pretty=format:'%Cred%h%Creset -%C(yellow)%d%Creset %s %Cgreen(%cr)%Creset' --abbrev-commit --date=relative | grep brcmfmac > log_file
Alternatively, go to "drivers/net/wireless/broadcom/brcm80211/brcmfmac" and issue the above command.
Linux GIT log (git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git)
Preview:
dd2349121bb1 - brcmfmac: Add check for short event packets (5 weeks ago)
35f62727df0e - brcmfmac: setup passive scan if requested by user-space (7 weeks ago)
17df6453d4be - brcmfmac: add length check in brcmf_cfg80211_escan_handler() (7 weeks ago)
f957dd3c8db2 - brcmfmac: feature check for multi-scheduled scan fails on bcm4345 devices (8 weeks ago)
f38966a7ace8 - brcmfmac: Log chip id and revision (10 weeks ago)
8b943e36e24a - brcmfmac: add setting carrier state ON for successful roaming (3 months ago)
99976fc08412 - brcmfmac: fix wrong num_different_channels when mchan feature enabled (3 months ago)
0ec9eb90feec - brcmfmac: Add support for CYW4373 SDIO/USB chipset (3 months ago)
fdfb0f94bfb7 - brcmfmac: set wpa_auth to WPA_AUTH_DISABLED in AP/OPEN security mode (3 months ago)
Cypress GIT log (git://git-iot.aus.cypress.com/wiced/hnd/brcm/linux/brcm80211.git)
- Attached the complete file cy_log.txt for reference.
Preview:
a7c9acc452b2 - brcmfmac: Delete redundant length check (5 weeks ago)
73f2c8e933b1 - brcmfmac: Avoid possible out-of-bounds read (5 weeks ago)
30ac40763939 - brcmfmac: use setup_timer() helper (6 weeks ago)
e66d70b789d1 - brcmfmac: constify pci_device_id (3 months ago)
e9bf53ab1ee3 - brcmfmac: feature check for multi-scheduled scan fails on bcm4343x devices (3 months ago)
