- Mark as Read
- Email to a Friend
- Printer Friendly Page
LED with PWM
Hello, here is how you can turn on an LED using PWM.
Include Library
#include "pwm.h"
#include "gpiodriver.h"
Define Macros
#define LED_RED 26 /* PWM 0 */ #define LED_BLUE 27 /* PWM 1 */ #define LED_GREEN 28 /* PWM 2 */ #define GPIO_PORT(x) (x/16) #define GPIO_PIN(x) (x%16) #define ENABLE_LED_RED PWM0_OUTPUT_ENABLE_P26 #define ENABLE_LED_BLUE PWM1_OUTPUT_ENABLE_P27 #define ENABLE_LED_GREEN PWM2_OUTPUT_ENABLE_P28 #define DISABLE_LED_GPIO GPIO_INPUT_ENABLE | GPIO_PULL_DOWN #define LED_RED_CHANNEL (PWM0) #define LED_BLUE_CHANNEL (PWM1) #define LED_GREEN_CHANNEL (PWM2)
Note: depending on which chip you are using, the GPIO Pins might change
Enable LED
// enable gpio_configurePin(GPIO_PORT(LED_RED), GPIO_PIN(LED_RED), ENABLE_LED_RED, 0); pwm_start( LED_GREEN_CHANNEL, LHL_CLK, 0x000 , 0); // pwm_start( id, clk, toggleCount, initCount); // Output Voltage | Toggle Count (Found these values by trial & error) // -------------------------------------------- // ~ (4/4) V_MAX | 0x000 // ~ (3/4) V_MAX | 0x100 // ~ (2/4) V_MAX | 0x210 // ~ (1/4) V_MAX | 0x315
Note: depending on the hardware configuration, the V_MAX may change
Disable LED
// disable gpio_configurePin(GPIO_PORT(LED_RED), GPIO_PIN(LED_RED), DISABLE_LED_GPIO, 0); pwm_disableChannel( 1 << LED_RED_CHANNEL );
References
Hardware User Guide (SDK 2.x and TAG3 Board)
James
- Mark Article as New
- Mark Article as Read
- Email to a Friend
LED_green is assigned to p14 but your enablement for green below is P13, and the same for blue. Is this an error?
#define LED_RED 26
#define LED_GREEN 14
#define LED_BLUE 13
#define ENABLE_LED_BLUE PWM2_OUTPUT_ENABLE_P14
#define ENABLE_LED_GREEN PWM3_OUTPUT_ENABLE_P13
- Email to a Friend
P13 (PWM3) and P28 (PWM2) are dual bonded at Pin 39. You have chosen to use P13 for Blue_LED. Someone reported that P28 has to be turn off explicitly, otherwise you will get both PWM3 and PWM2 signals at Pin 39! This could be a reason why you are seeing the wrong colour and/or a mixture. You will need to add the below to turn off P28:
gpio_configurePin((GPIO_PIN_P28) / 16, (GPIO_PIN_P28) % 16, GPIO_INPUT_ENABLE, 0);
Re: How many PWM channels available in BCM20732S ?
I also noted that in your present configuration, PWM0 and 3 can sink/source up to 16mA whereas PWM2 can sink/source only up to 2mA.
Let me know if it helps.
- Email to a Friend
I also noted in pwm_tones app that the configuration of the GPIO (gpio_configurePin) occurred after calling pwm_start. Can you try this as well?
Can you re-post your latest code?
- Email to a Friend
Can you state again what is the LED pattern that you want to create?
You have three LEDs, and you want to toggle from one to another using a interrupt?
And what is your test platform? Are you using a tag4 or your own board with the SIP?
I tested out the LED app and another push_button_led_interrupt app separately on a tag4 and there wasn't any issue with those GPIO bonded pins or settings. It is not obvious to me what could be wrong in your code unless I test it out.
- Email to a Friend
Could you create a new discussion as comments on blogs are really not designed to support debug sessions.
Thanks in advance for your understanding.
Mike
btta
- Email to a Friend
I created Issue Blinking 3 led using PWM on dual bonded pin
I will cleanup the post I did on this thread. Feel free to update some of your comment at the new location
