- Mark as Read
- Printer Friendly Page
Graphics library on STM based platforms
To use the graphics library on STM based platforms, download the attached file and replace the files in WICED/platform/STM32FXxx/peripherials/
To run the graphics snip apps, add the necessary platforms to the valid platform list in the makefile.
Modify the I2C port in the wiced_i2c_device_t variable if necessary; by default, the 43364 platform has only one I2C port defined.
Connect the display to the evaluation board and download the snip app.
snip.graphics.graphicstest-BCM943364WCD1 download run
- Mark Article as New
- Mark Article as Read
Hello aky,
Many thanks to your share, this really helps us. Now,the OLED can work on our BCM4343W_AVN platform.
Hello lzb_1777891
Can you possibly share example code that you used with the BCM4343W_AVN board? (+ your SSD1306 based OLED display)
Peter
