Example code of fetching UVC data from FX3
YiZ_31
This is an example program based on libusb that automatically takes the first frame and streams data from the endpoint then calculates the FPS.
Please notice that only bulk transfer is supported in the current version. This application does not contain a decoder so RAW format is also supported.
https://github.com/zhao1mh/videotest
