Anna-xuan
25 sign-ins 10 replies posted First like received
i'm using matlab,perform the presence_detection,with  BGT60TR13C,when i  was  progressing  the step,my code  shows  something wrong  as  png  i was  uploaded.it shows 'Dev = RadarDevice();'  is  wrong.
Thank you,Neo  lu
I've found  the problem  some minutes ago.it's blame  the version of matlab,my  computer  installed  2021b matlab .I  uninstalled it then and  downloaded  2018b  matlab.Then  the problem is  solved.
Thank you for your reply!
Neo_Lu
50 replies posted 5 likes given 100 sign-ins
  2. Please try flash the firmware in Radar Fusion GUI before using the MATLAB SDK.
Hope that will help you,
Neo Lu
Thank you,Neo  Lu
Neo_Lu
OK, keep on communication if the problem still there.
Thank you,Neo  lu
Neo_Lu
Thanks, .
Lots of work you have done.
