parikshagarg040
10 questions asked 25 sign-ins 10 replies posted
can you tell us how to make range or doppler spectrogram using bgt60tr13c demo board.
https://www.mdpi.com/1424-8220/22/4/1519  like as shown in this paper. in this paper spectrogram is shown by using bgt60tr13c sensor
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @parikshagarg040,
Please refer Radar SDK Document available at the path mentioned above.
Additionally, you can also refer the following thread to build applications https://community.infineon.com/t5/Radar-sensor/How-to-upload-and-build-the-code-examples-on-BGT60TR1...
After the build is  successful, you can find the .exe applications generated in the bin folder of radar_sdk directory
Connect the board to your PC and run app_rdm.exe to get the output of range doppler map
To flash the firmware on to the MCU7 Base Board use "UpdateFirmware batch file" available at the path C:\Infineon\Tools\Radar Development Kit\3.3.1.202211181510\assets\software\firmware-rbb7\Firmware
Note: The applications run at the host side(e.g. PC)
Pugitha
Pugitha_N
Infineon has Range Doppler Map algorithm in its Radar Development Kit. You can implement the application using the algorithm present at the path C:\Infineon\Tools\Radar Development Kit\3.4.0.202304141149\assets\software\radar_sdk\radar_sdk\sdk\c\ifxRadar
You can also refer to the documentation present in the doc folder for more information on the algorithms
Pugitha
parikshagarg040
C:\Infineon\Tools\Radar Development Kit\3.4.0.202304141149\assets\software\radar_sdk\radar_sdk\sdk\c\ifxRadar how to run these c code in bgt60tr13c module.
Pugitha_N
Pugitha
