parikshagarg040
10 questions asked 25 sign-ins 10 replies posted
how can we see two moving objects in range angle map at a same time.
Honey_D
5 comments on blog 50 likes received 250 replies posted
Hello @parikshagarg040 ,
Range and Angle Measurement plot can only track one target. Modify the sensitivity to lessen the probability of disappearance of target on Range and Angle Measurement plot.
We can't judge Range spectrum inferring Range and Angle Measurement plot because the waveforms of Range spectrum depict multiple targets but as already said Range and Angle Measurement plot will only target the nearest moving target, you can't analyze which target on Range Spectrum is getting plotted on Range and Angle Measurement plot.
We would recommend you to go through Segmentation Algorithm for plotting two targets at the same time and plot
Hope this helps!
Honey
Honey_D
Hope this helps!
Honey
