I notice that a company called Blumio develops a kind of wearable blood pressure measuring device with BGT60TR13C. The measuring distance is about 1 cm to human's wrist. I wonder how I can configure BGT60TR13C to work in a proximal distance (maybe below 5 cm). I cannot manage to configure the device to work in such a short distance.
Hey @shibiana
The error states that the frequency settings are out of the range, please check your Start and end frequency to be in the range of 58- 63.5 GHz. If it still doesn't work try with a fresh code by only changing the max range (chances are you might have changed some other configurations).
Thankyou, Siddharth
The minimum range you can configure in the Fusion GUI is 10 cm. But, you can set range as small as 1 cm in RDK apps, say for example, you want to use the app_raw_data.c then you can set the max_range_m to 1 cm inside RadarDeviceBase.cpp. See the image below for more details.
Hope this helps, Thankyou
Siddharth
Thank you! I tried to set the configuration as 5 cm or even 1 cm in the RadarDeviceBase.cpp. But it showed as below. I wonder if you can make sure that the device can work in this short distance? By the way, I set as Low-power short-range measurement as the official pdf(AN600 BGT60TR13C shield) shows and it also shows errors when I run the code. Sorry to trouble you.
Hey @shibiana
Thankyou, Siddharth
Hope your query was resolved. We will be locking this thread due to inactivity, please feel free to create a new query on similar or other issues. Thankyou
