Chris23
First question asked Welcome!
Hi all!
I can't find the ifxradarsdk-3.5.0-py3-none-any.whl in my current version of the radar_sdk. According to the quick start it is supposed to be under libs/platform/ right?
However, I found the ifxradarsdk-3.5.0+8c595dbb-py3-none-win_amd64.whl in the python_wheels folder but when trying to install it on windows using pip it gives me this error message:
ERROR: ifxradarsdk-3.5.0+8c595dbb-py3-none-win_amd64.whl is not a supported wheel on this platform.
I already updated pip but is there anything else that I could try?
Thanks!
Honey_D
5 comments on blog 50 likes received 250 replies posted
Hello @Chris23 ,
To build the Python wheels make sure that python is installed, and that pip, wheel, and setup tools are up to date, if they are not up to data run the below given command
python -m pip install --upgrade pip wheel setuptools
The python wheels can be found in the folder path: \radar_sdk\python_wheels. Please refer the following snap shot as reference:
You can also refer to some article as well for working around with Radar development kit:  https://community.infineon.com/t5/Knowledge-Base-Articles/Radar-Development-Kit-RDK-presence-detecti... , https://community.infineon.com/t5/Blogs/The-ultimate-tool-Radar-Development-Kit/ba-p/442424
Hope this helps!
Honey
Honey_D
Hello @Chris23 ,
Hope this helps!
Honey
