小白爱学习
5 likes given 5 questions asked 25 sign-ins
An error occurred after linking the camera and radar。
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @小白爱学习,
We checked with D405 camera and had the hope that this camera could have been supported with some simple changes. However, we found that this would cause more efforts to integrate it into our toolchain which is currently not planned. Currently ifxdaq supports only D455.
Pugitha
小白爱学习
Hello, everyone. I have the following problems when I use ifxdaq.
qt.pysideplugin: Environment variable PYSIDE_DESIGNER_PLUGINS is not set, bailing out.
How can I solve them?
Pugitha_N
Hello @小白爱学习,
qt.pysideplugin: Environment variable PYSIDE_DESIGNER_PLUGINS is not set, bailing out is just the warning from underlying external library.
Are you able to record in general after the set-up. If not can you please share us the log  files. They are stored under ~/.cache/ifxdaq/logs
Pugitha.
Thank you for your answer. Only radar sensors can record it. I can find the device when I add the D405 Intel depth camera (different from the D455), but there is an error in recording, and it still doesn't work when I change the exported camera profile. Is there any way to solve it?
Pugitha_N
Hello @小白爱学习,
Please share us the logs as mentioned above to analyze your issue.
Pugitha
The log is already in the attachment above, specifically due to the use of a different type of sensor than the default D455 sensor, but I only have the same series of D405 depth cameras how to modify the json file to make the software work. There is no detailed description in this part of the document. Can you give me some specific settings? Thank you very much.
Pugitha_N
Hello @小白爱学习,
~/.cache/ifxdaq/logs, share us the  logs directory.
B.R
Pugitha
Failed after repeated attempts, these are my logs and my device configuration.
Pugitha_N
Hello @小白爱学习,
can you please run ifxdaq sysinfo  and share the result with us
Pugitha.
小白爱学习
The device can be found ,and the settings are exported from intel view. After modification, the software cannot work.
小白爱学习
Can you tell me how to set different types of depth camera parameters so that it can adapt to ifxdaq.
Pugitha_N
Hello @小白爱学习,
Pugitha
