HI,I need to realize the function of people counting with 60GHZ sensor.When i read related information,i found there's two board during the solution as pictures below.I have owned the first one,so do they have differences?Should i buy another one?
- BGT60TR13C
- CSK
- SoM
- Wing
Hi @Anna-xuan
Yes, The I/O board is part of the evaluation kit for Infineon’s Smart Entrance Counter solution. You will not need the I/O board as you already have the DEMO BGT60TR13C board.
Thanks and regards.
Siddharth
Hi @Anna-xuan
The first board you own is a XENSIV™ 60GHz BGT60TR13C system-on-module (SoM) a.k.a Form Factor (FF) board, the second image you have put up also contains the same board with an additional board which is the I/O board, The BGT60TR13C SoM sits on this I/O board. The SoM and the I/O board together form the 'KIT BGT60TR13C EMBEDD'. Further, This I/O board enables the connection of SoM to the PC via USB for configuration and evaluation purposes. This is a Plug and Play solution for Presence detection which comes with an associated GUI application. Yes, you will need the I/O board if your application requires interfacing the BGT60TR13C SoM with a PC for the same.
These links might come in handy,
1- https://www.infineon.com/cms/en/product/promopages/smart_entrance_counter_solution/#!?videoId=AVqh6y...
2- https://www.infineon.com/dgdl/Infineon-SmartEntranceCounterSolution-ProductPresentation-v01_00-EN.pd...
Hope this helps.
Thanks and regards
Siddharth
Hi,Siddharth
Thank you for your reply!But i've already link the BGT60TR13C to pc,the I/O board is just to link the BGT60 to the pc?
Hi @Anna-xuan
Thanks and regards.
Siddharth
Hi,Siddharth
Thank you for your help!
Thanks and regards.
Anna Xuan
