Hi everyone,
I'm using 24GHz Distance2Go radar hardware right now. Here I found a parameter called 'min frame interval' according to the API document.
I want to know what does this parameter stand for? Is it the time between the starting point of two adjacent frames or is it the time between the ending point of the last frame and the starting point of the current frame. Just like I painted below.
Radar Sensor
- 24ghz
- bgt24mtr11
Hello @LouisEE ,
Minimum frame interval is defined as the time interval between the start and end of frame during data acquisition.
Hope this helps
Honey
Hello @LouisEE ,
Hope this helps
Honey
