user25192
10 sign-ins 5 sign-ins First reply posted
I have managed to implement a function to print the values for the USB port of the radar settings and the values of the targets but I could not obtain the same results using the same parameters used in the GUI interface in the config.h file, even having the fixed objects in the same position. I'm using the example code found in the P2G_FMCW. Help?
Montassar-BR
50 likes received 5 questions asked 250 sign-ins
Please try to use the provided Com_Lib interfaces (C or MATLAB) based, to get data from the radar sensor. That would be the best way to avoid debugging your implemented print function over USB...
Thanks to try it out, and let us know about your findings.
Cheers,
Montassar.
Montassar-BR
Cheers,
Montassar.
