lalit
Please explain how the timestamp values are created in the output file .txt.
I want to match the timestamp of doppler radar data with the video data. Do I have to use the entire timestamp value (for eg., Timestamp = 1678281503 ). Please see the attached txt file.
Thanks !
Siddharth_H
100 solutions authored 50 likes received First question asked
Hi @lalit ,
The time stamp, for example 1678281503 is the number of seconds elapsed since January 1, 1970. This timestamp is called Unix epoch or Unix time or POSIX time or Unix timestamp.
To calculate the date time out of this value, you can simply use the inbuilt functions available for the language you are using. For example in python, you can use datetime library to convert this to human readable date and time. See the sample code below to do it.
You can copy the code below.
import datetime
epoch_time = 1678281503
date_time = datetime.datetime.fromtimestamp(epoch_time)
print("Date and time=", date_time )
Or you can also write your own algorithm to convert it.
Thank you, Siddharth.
Siddharth_H
Hi @lalit ,
import datetime
