Jan 12, 2023
04:56 PM
Jan 12, 2023
04:56 PM
What is the difference between IRS1645C and IRS2381C?
Can you also email me up the datasheet and any reference designs you might have for both?
09:51 PM
Jan 16, 2023
09:51 PM
IRS1645C is 850nm Wavelength used for Robotics Applications.
IRS2381C is 940nm Wavelength used for Smartphones and Mobile device Applications.
the datasheet is not available publicly if you looking for module as final application I suggest to contact module partners based on location and need from this link - https://www.infineon.com/cms/en/partners/ecosystems/tof-3d-image-sensors-for-automotive/
If you looking to partner with us for Bare die please contact us over https://mycases.infineon.com/ or connect local FAE.
Biren
