fkumar
Hi Team,
I am new to this TOF 3D sensor to develop the people counting application. How many people are in and out information is trying to fetch from your sensor. Please recommend the right sensor to interface with MCU or MPU please let us know. Will these products be running on MCU or MPU platforms?
Regards, Kumar
AliAsgar
1000 replies posted 250 solutions authored 750 replies posted
Hi Kumar,
Infineon provides two types of sensors for the application you are looking for (people counting)
1. ToF sensor: Infineon provides a wide range of highly integrated ToF imagers. However, the camera module with these ToF imagers has to be procured from our partner network. Please find details of the Infineon's REAL3 ToF imagers and the partner network from the given link : https://www.infineon.com/cms/en/product/sensor/tof-3d-image-sensors/
Usually these camera modules can be connected to the host through USB.
2. 60 GHz Radar sensor: BGT60TR13C will be suitable for people counting application, please through the Shield and Demo board product page for further details.
You may also go through our Smart Entrance Counter solution (https://www.infineon.com/dgdl/Infineon-EntranceCounterSolution_with_60GHzRadar-ProductBrief-v01_00-E...) for you reference.
AliAsgar
AliAsgar
Hi Kumar,
AliAsgar
Hi AliAsgar,
Thanks for your response.
I am looking for people coming in and out both the counts are required to capture by your module.
Right now I made the board based on ST based TOF sensor and made the people counting algorithm which is not sensing all the photons based on humans.
I am looking for a solution that should work for entrance in and out counting purposes like you.
Now we need the both people counting method to trace how many people are entering and leaving from the door entrance. I believe the final output you're through over UART. What is the output  you're throwing over UART? Is 'IN' and 'OUT' both count?
Do you have a similar solution which can be seen based on your EVK then we will use the same login in our products.
Can the above link module directly give the IN and OUT count from UART end we will attach our board and get the results.
Kumar
AliAsgar
Hi Kumar,
The smart entrance solution with BGT60TR13C can provide both the IN and OUT counter values over UART.
Please refer to the given github link for code example for PSoC6 used in the EMBED eval board: https://github.com/Infineon/mtb-example-sensors-radar-entrancecounter-freertos
AliAsgar
