Synchronize BGT60TR13C sensors
NBRadar
is it possible to make an array with more sensors and synchronize the RF-Signal?
Deepa_V
First comment on KBA 50 likes received 250 replies posted
Hi @NBRadar ,
You'll have to synchronize the sensors on the firmware side.
Deepa
Deepa_V
Hi @NBRadar ,
In theory it should be possible but there is a high chance of interference and cross-talk if the sensors are working at the same time as they have the same frequency range. Additionally, you can try adjusting the Field of view to reduce the interference but please note that this hasn't been tested from our side. Else if you want to make the sensors lined up and work one at a time,  your firmware would need to ensure that one shield is active when the other is in idle.
Hope this helps !
Deepa
Hi @Deepa_V ,
thank you for the answer. Can i synchronize the sensors with the OSC_CLK Input or only with Sotfware?
The interference is intentional for beamforming, but therefor all emitted waves should be in phase.
Deepa_V
Hi @NBRadar ,
Deepa
