rajesh_ut
First reply posted First like given First question asked
I am trying to design and build low cost radar that can penetrate through ground for at least 500mm. The use cases will be detecting the underground pipelines before doing repair works on them and avoid damaging cables buried underground during road maintenance or erecting poles. Is there any low cost ground penetrating radar sensor available in the infineon product line up?
Siddharth_H
100 solutions authored 50 likes received First question asked
Hey @rajesh_ut ,
Infineon doesn't have any radar product that is capable of penetrating through ground.
Infineon offers only 24, 60 and 77 GHz radars and these frequency are not capable of penetrating through the ground. You should be looking for 10 MHz to 2.6 GHz range to be able to penetrate through ground.
Thank you,
Siddharth.
Siddharth_H
Hey @rajesh_ut ,
Thank you,
Siddharth.
Thank you for the clarification
