thangbm3
I am using BGT60TR13C evaluation boards. I have 4 radars and write a single program in Linux to implement Segmentation Algorithm in each radar sequentially to have 360 degree environment.
When I set up only an obstacle in front of the first radar. The result should appear from only the 1st radar but all 4 radars show the same results.
Is it possible to implement segmentation algorithm in multiple radar as I do? Could anyone explain to me about this problem?
Thank you for your help!
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @thangbm3,
Is there any interference between the fields of view (FOVs) of each radar?
Did you try the segmentation algorithm available in RDK with your set-up?
Pugitha
Pugitha_N
Hello @thangbm3,
Would it be possible for you to provide a detailed overview of your setup, possibly with images? This would help me better understand your configuration and provide more accurate responses.
Pugitha.
Thank you for your reply.
Here is the detail in my program:
Firstly, I initialize 3 radars with their port names
[image: image.png]
There is the code inside the init function:
[image: image.png]
The function "m_radar.init()" sets up all configurations before the while
loop.
After that, I call the "run" function to read data from each radar:
[image: image.png]
This is the code inside "getRadarPoints()" function:
[image: image.png]
I set up 3 radars on 3 faces of a cube and the obstacle moves in front of
the first radar.
However, the result of 3 radars are the same:
[image: image.png]
That's all my program
Thank you
Thang
Pugitha_N
Hello @thangbm3,
Pugitha
