SDK BGT60TR13C Avian.Recording
AMEE23
5 replies posted 10 sign-ins First like given
I am trying to open a recording using sdk. I currently have:
recording_handle = "my path to directory"
with Avian.Recording() as recording_handle:
with Avian.Device(recording = recording_handle, correct_timing=False) as device:
I get the following error:
ifxAvian.Error.ErrorOpeningFile: cannot open file - it might not exist or is corrupted (IFX_ERROR_OPENING_FILE)
I appreciate any help, thank you.
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @AMEE23,
Please follow the steps mentioned below
1. Recording using the App Recorder
e.g. for 100 frames:
app_recorder.exe -r record_test -o record_test -f 100
2. Convert using DAQ Kit
e.g:
daqkit_converter.exe -d record_test -c record_test_config.json -p record_test
This step 2. will generate a folder that should be pointed at (path_to_recording) by the example_recording.py python wrapper.
In the python script, the index can be adapted to the RadarIfxAvian_00 desired recording folder
Pugitha
Pugitha_N
Hello @AMEE23,
Please check if you have given correct path and name of your saved recording file.
Refer the example_recording.py file from the following path C:\Infineon\Tools\Radar Development Kit\3.4.0.202304250920\assets\software\radar_sdk\radar_sdk\sdk\py\wrapper_avian for recording example.
Pugitha.
Hi @Pugitha_N , I have tried to follow the example as posted in the example recording
I have file saved as: RadarIfxAvian_00.bin
I currently have the following :
path_to_recording_parent_dir = "my parent path"
with Recording(path=path_to_recording_parent_dir, mode=0, type=0, index=0) as recording:
with Device(recording=recording, correct_timing=False) as device:
print("here")
File "..\site-packages\ifxAvian\Common.py", line 98, in check_rc
raise_exception_for_error_code(error_code, error_description)
File "..\site-packages\ifxAvian\Error.py", line 95, in raise_exception_for_error_code
raise globals()[error_name](error_description)
Pugitha_N
Hello @AMEE23,
You have to load the recording file in .txt format not in .bin file format. If you're recording using GUI, you can select the .txt format in recoding settings.
Pugitha.
Hi @Pugitha_N ,
Thank you for taking the time to reply, could you please provide an example of how I should write this with a test file attached? I have attempted the solution you suggested, saving the recording as a .txt file but this yields the same error as above. Thank you in advance.
Full Error Log:
C:\Users\dianamorales\anaconda3\python.exe C:\Users\dianamorales\Downloads\examples\static_distance-recording-demoBoard.py
Traceback (most recent call last):
File "C:\Users\dianamorales\Downloads\examples\static_distance-recording-demoBoard.py", line 315, in <module>
with Avian.Recording(path=path_to_recording_parent_dir, mode=0, type=0, index=0) as recording:
File "C:\Users\dianamorales\anaconda3\lib\site-packages\ifxAvian\Common.py", line 72, in inner
check_rc(dll)
File "C:\Users\dianamorales\anaconda3\lib\site-packages\ifxAvian\Common.py", line 98, in check_rc
File "C:\Users\dianamorales\anaconda3\lib\site-packages\ifxAvian\Error.py", line 95, in raise_exception_for_error_code
Process finished with exit code 1
Pugitha_N
Hello @AMEE23,
Can you please share your recording file with us. Are you just trying to open the recording file?
Pugitha.
Hi @Pugitha_N
I have attached the raw.txt file as a .zip file as .txt was not an accepted format. Thank you in advance.
Best,
amee
Hi @Pugitha_N
Did the file work on your end?
Best,
amee
Pugitha_N
Hello @AMEE23,
We are looking into your issue. Thank you for your patience.
Pugitha.
jeremylaw
First reply posted First like given Welcome!
I am having the same issue.
Pugitha_N
Hello @AMEE23,
e.g:
Pugitha
